No currently I think not. I would propose to use OPC UA. Is there a public API for FactoryTalk Communication. If yes it could be easily integrated with some programming.
Hi Andy, oh sorry. Yes you can remove this line.
Give us a good feedback in the Unity Store if you are happy with our solution. Thanks.
If everything is OK it will be included in the next release (which will be available in the Asset Store most probably tomorrow).
Hi Andrew,
this new code for CADLink.cs should fix your issue. Please check and give me feedback.
// Game4Automation (R) Framework for Automation Concept Design, Virtual Commissioning and 3D-HMI
// (c) 2019 in2Sight GmbH - Usage of this source code only allowed based on License conditions see https://game4automation.com/lizenz
using System.IO;
using System.Linq;
using UnityEngine;
using NaughtyAttributes;
using ThreeMf;
using UnityEditor;
using System.Collections.Generic;
using UnityEngine.Analytics;
using UnityScript.Steps;
public class CADLink : MonoBehaviour
[BoxGroup("Import CAD")] public string File;
[BoxGroup("Import CAD")] public bool DeleteBeforeImporting;
[BoxGroup("Import CAD")] public bool RemoveTopAssemblyNode = false;
[BoxGroup("Import CAD")] public bool NameClonesIdentical;
[BoxGroup("Import CAD")] public float ImportScaleFactor = 0.001f;
[BoxGroup("Import CAD")] [ReadOnly] public string Status = "";
[BoxGroup("Advanced")] public bool ImportDistinctVertices = true;
[BoxGroup("Advanced")] public bool UnityRecalculateNormals = false;
[BoxGroup("Advanced")] public bool AdvancedRecalculateNormals = true;
[BoxGroup("Advanced")] [EnableIf("AdvancedRecalculateNormals")]
public float AdvancedRecalcluateNormalsAngle = 30;
[BoxGroup("Advanced")] [InfoBox("UV Mapping takes long - just use if needed")]
public bool CalculateUVS = false;
[EnableIf("CalculateUVS")] [BoxGroup("Advanced")]
public float UVScalfactor = 1.0f;
[BoxGroup("Materials")] public bool SetAndCreateMaterials = true;
[BoxGroup("Materials")] [EnableIf("SetAndCreateMaterials")]
public bool OverwriteExistingMaterials = false;
public string NewMaterialPath;
public MaterialMapping MaterialMapping;
private bool SetPositions = true;
private float Progress = 0;
private bool cancel = false;
private List<Material> newmaterials = new List<Material>();
private List<CADPart> nosubcomponent = new List<CADPart>();
[Button("Create New Material Mapping")]
private void CreateMeaterialMapping()
#if UNITY_EDITOR
var mapping = CreateAsset<MaterialMapping>();
MaterialMapping = (MaterialMapping) mapping;
[Button("Update Materials")]
private void SetMaterials()
newmaterials.Clear();
// Go through all CAD parts with meshes and check if material is assigned
// if not assign next material of upper levels
CADPart[] cadparts = GetComponentsInChildren<CADPart>(this);
foreach (CADPart cadpart in cadparts)
MeshFilter meshfilter = cadpart.GetComponent<MeshFilter>();
Renderer meshrenderer = cadpart.GetComponent<Renderer>();
if (meshrenderer != null)
// Part with Mesh has material assigned
if (cadpart.Color != "" || cadpart.Material != "")
meshrenderer.sharedMaterial = Get3mfMaterial(cadpart.Color, cadpart.Material);
// if not find next CADpart upwards with Material
Component[] uppercadparts = cadpart.GetComponentsInParent(typeof(CADPart), true);
foreach (CADPart uppercadpart in uppercadparts)
if (uppercadpart.Color != "")
meshrenderer.sharedMaterial = Get3mfMaterial(uppercadpart.Color, uppercadpart.Material);
break;
[Button("Select CAD Import File")]
void SelectFile()
#if UNITY_EDITOR
File = EditorUtility.OpenFilePanel("Select file to import", File, "3mf");
[Button("Delete Import")]
public void DeleteAll()
CADPart[] children = transform.GetComponentsInChildren<CADPart>();
foreach (var child in children.ToArray())
if (child != null)
DestroyImmediate(child.gameObject);
public void Log(string message)
Debug.Log("Game4Automation CAD Import: " + message);
#if UNITY_EDITOR
cancel = EditorUtility.DisplayCancelableProgressBar(
"CAD Livelink - Import",
message,
Progress);
Status = message;
[Button("Import CAD File")]
public void ImportCad()
cancel = false;
if (!System.IO.File.Exists(File))
#if UNITY_EDITOR
EditorUtility.DisplayDialog("ERROR", "3MF File at defined path [" + File + "] not existing.", "OK", "");
return;
Debug.LogError("3MF File at defined path [" + File + "] not existing.");
if (!Directory.Exists(NewMaterialPath) && SetAndCreateMaterials)
#if UNITY_EDITOR
EditorUtility.DisplayDialog("ERROR", "New material path [" + NewMaterialPath + "] not existing.", "OK",
return;
if (DeleteBeforeImporting)
DeleteAll();
Progress = 0.05f;
var num = 0;
nosubcomponent.Clear();
Log("Load 3MF File");
var test = ThreeMfFile.Load(File, 1);
Debug.Log("Import 3MF");
// Import Positions and Meshes for all Ressources
foreach (var model in test.Models)
foreach (var resource in model.Resources)
num++;
Progress = (float) num / (float) model.Resources.Count;
if (cancel)
Debug.Log("Import Canceled by User");
#if UNITY_EDITOR
EditorUtility.ClearProgressBar();
return;
if (resource.GetType() == typeof(ThreeMfObject))
var obj = (ThreeMfObject) resource;
Log("Import Part " + obj.Name + " " + obj.Id.ToString());
var part = CreateCadPart(this.gameObject, obj.Name, obj.Id.ToString(), obj);
part.File = File;
part.LastUpdate = System.DateTime.Now.ToString();
// Mesh at Part
if (obj.Mesh != null)
CreateMesh(part, obj.Mesh);
// Get Porpertyindex
var propindex = obj.PropertyIndex;
// Properties at Part
if (obj.PropertyResource != null)
if (obj.PropertyResource.PropertyItems != null)
var currindex = 0;
foreach (var propertyItem in obj.PropertyResource.PropertyItems)
if (currindex == propindex)
Material material = null;
if (propertyItem.GetType() == typeof(ThreeMfColor))
var color = (ThreeMfColor) propertyItem;
part.Color = color.Color.ToString();
part.Material = "";
if (propertyItem.GetType() == typeof(ThreeMfBase))
var color = (ThreeMfBase) propertyItem;
part.Material = color.Name;
currindex = currindex + 1;
foreach (var component in obj.Components)
MakeAsSubComponent(obj.Id.ToString(), component.Object.Id.ToString(), component);
// Set Positions for Build information
foreach (var item in model.Items)
SetBuildPosition(item);
if (SetAndCreateMaterials)
SetMaterials();
if (RemoveTopAssemblyNode)
RemoveTopAssembly();
#if UNITY_EDITOR
private void RemoveTopAssembly()
var top = nosubcomponent[0];
List<GameObject> children = new List<GameObject>();
if (top != null)
for (int i = 0; i < top.transform.childCount; i++)
children.Add(top.transform.GetChild(i).gameObject);
foreach (var child in children)
child.transform.parent = this.transform;
DestroyImmediate(top.gameObject);
private Material Get3mfMaterial(string colorname, string materialname)
Material newmaterial = null;
// colorname.Replace("#", "Hex");
var tempMaterial = new Material(Shader.Find("Standard"));
// check if material assignment in material mapping
// 1st check if color and material combination are defined
if (MaterialMapping != null)
foreach (var mapping in MaterialMapping.Mappings)
if (mapping.Colorname == colorname && mapping.Materialname == materialname)
return mapping.Material;
// 2nd check if material is defined
if (mapping.Materialname == materialname && mapping.Materialname != "")
// 3rd check if color is defined
if (mapping.Colorname == colorname && mapping.Colorname != "")
#if UNITY_EDITOR
// create new material if not existing
string[] assets = AssetDatabase.FindAssets(colorname + " t:material");
bool createnewmaterial = true;
if (assets.Length != 0 && OverwriteExistingMaterials == false)
createnewmaterial = false;
if (assets.Length != 0 && OverwriteExistingMaterials == true)
newmaterial = AssetDatabase.LoadAssetAtPath<Material>(AssetDatabase.GUIDToAssetPath(assets[0]));
if (newmaterials.Contains(newmaterial))
AssetDatabase.DeleteAsset(AssetDatabase.GUIDToAssetPath(assets[0]));
if (createnewmaterial)
var path = Path.Combine(NewMaterialPath, colorname + ".mat");
AssetDatabase.CreateAsset(tempMaterial, path);
newmaterial = AssetDatabase.LoadAssetAtPath<Material>(path);
newmaterials.Add(newmaterial);
var col = new Color();
ColorUtility.TryParseHtmlString(colorname, out col);
newmaterial.color = col;
#else
newmaterial = new Material(Shader.Find("Standard"));
return newmaterial;
private void CreateMesh(CADPart part, ThreeMfMesh mesh)
MeshFilter meshfilter = part.transform.GetComponent<MeshFilter>();
if (meshfilter == null)
meshfilter = part.transform.gameObject.AddComponent<MeshFilter>();
MeshRenderer meshrenderer = part.transform.GetComponent<MeshRenderer>();
if (meshrenderer == null)
meshrenderer = part.transform.gameObject.AddComponent<MeshRenderer>();
Mesh umesh = new Mesh();
umesh.name = part.gameObject.name;
umesh.vertices = mesh.uVertices.ToArray();
umesh.triangles = mesh.uTriangles.ToArray();
if (ImportDistinctVertices)
CADMeshTools.DistinctVertices(ref umesh);
if (UnityRecalculateNormals)
umesh.RecalculateNormals();
if (AdvancedRecalculateNormals)
CADMeshTools.RecalculateNormals(umesh, AdvancedRecalcluateNormalsAngle);
if (CalculateUVS)
CADMeshTools.CalculateUVS(ref umesh, UVScalfactor);
if (ImportScaleFactor != 1)
CADMeshTools.ScaleMesh(ref umesh, ImportScaleFactor);
meshfilter.mesh = umesh;
private CADPart CreateCadPart(GameObject parent, string name, string Id, ThreeMfObject threemfobject)
var part = GetCADPart(Id);
if (part == null)
// Create new part
var newobj = new GameObject(name);
part = newobj.AddComponent<CADPart>();
newobj.transform.parent = parent.transform;
newobj.transform.localPosition = new Vector3(0, 0, 0);
newobj.transform.localEulerAngles = new Vector3(0, 0, 0);
part.Id = Id;
part.Name = name;
part.Set3MFfObject(threemfobject);
nosubcomponent.Add(part);
return part;
public void SetBuildPosition(ThreeMfModelItem item)
var id = item.Object.Id.ToString();
var comp = GetCADPart(id);
comp.ImportPos = item.Transform.GetPosition() * ImportScaleFactor;
comp.ImportRotOriginal = item.Transform.Get3mfAngles();
comp.ImportScale = item.Transform.GetScale();
if (SetPositions)
comp.transform.localPosition = comp.ImportPos;
comp.transform.localRotation = item.Transform.GetRotationQuaternion();
comp.ImportRot = comp.transform.localRotation.eulerAngles;
public void MakeAsSubComponent(string idparent, string idchild, ThreeMfComponent component)
var parent = GetCADPart(idparent);
var child = GetCADPart(idchild);
nosubcomponent.Remove(child);
CADPart comp;
if (child.AssembledInto == null)
child.MakeAsSubCompponent(parent);
comp = child;
// Is Allready assembled into another component - make copy
var copy = child.CreateClone(NameClonesIdentical);
copy.MakeAsSubCompponent(parent);
comp = copy;
comp.ImportPos = component.Transform.GetPosition() * ImportScaleFactor;
comp.ImportRotOriginal = component.Transform.Get3mfAngles();
comp.ImportScale = component.Transform.GetScale();
if (SetPositions)
comp.transform.localRotation = component.Transform.GetRotationQuaternion();
private CADPart GetCADPart(string id)
if (child.Id == id && child.IsClone == false)
return child;
return null;
public static object CreateAsset<T>() where T : ScriptableObject
T asset = ScriptableObject.CreateInstance<T>();
#if UNITY_EDITOR
var find = AssetDatabase.FindAssets(
"StandardMaterialMapping t:ScriptableObject");
string path = AssetDatabase.GUIDToAssetPath(find[0]);
var theasset = AssetDatabase.LoadAssetAtPath<ScriptableObject>(path);
if (path == "")
path = "Assets";
else if (Path.GetExtension(path) != "")
path = path.Replace(Path.GetFileName(AssetDatabase.GetAssetPath(theasset)), "");
string assetPathAndName =
AssetDatabase.GenerateUniqueAssetPath(path + "/New " + typeof(T).ToString() + ".asset");
AssetDatabase.CreateAsset(asset, assetPathAndName);
AssetDatabase.SaveAssets();
AssetDatabase.Refresh();
return asset;
}I can't open the Solidedge file - can you please send it as a Step file.
OK thanks for the files. We received it. We will check it. Because we are nearly starting the weekend now it might take until Monday evening.
OK thanks. I am happy that at least the color problem is solved. We will also get solved the rest. You could delete everything in the parts and just leave some primitives which show me how it should be positioned. You could also additionally send me the Solidedge file - this will allow me to compare both.
Hi Andrew,
for the color problem (Solidedge has another way to use the ColorGroups) we will release an update soon. You can already replace CADLINK.cs with this file - this should help.
For the Assembly Positions I will need to check. Can you please send me an example exported 3mf from solidworks to info@game4automation.com.
using System.IO;
using System.Linq;
using UnityEngine;
using ThreeMf;
using UnityEditor;
#if UNITY_EDITOR
break;
void SelectFile()
#if UNITY_EDITOR
if (child != null)
#if UNITY_EDITOR
message,
Progress);
Status = message;
cancel = false;
#if UNITY_EDITOR
return;
#if UNITY_EDITOR
return;
DeleteAll();
Progress = 0.05f;
var num = 0;
num++;
if (cancel)
#if UNITY_EDITOR
return;
part.File = File;
// Mesh at Part
var currindex = 0;
part.Material = "";
SetMaterials();
#if UNITY_EDITOR
if (top != null)
#if UNITY_EDITOR
#else
return newmaterial;
if (CalculateUVS)
if (part == null)
// Create new part
part.Id = Id;
part.Name = name;
return part;
CADPart comp;
comp = child;
comp = copy;
if (SetPositions)
return child;
return null;
#if UNITY_EDITOR
if (path == "")
path = "Assets";
return asset;
}Customer support service by UserEcho
Thanks for the positive feedback. Because of vacation I can’t check the issue before Wednesday next week - but I will take care about it ASAP. And if you like it please give a positive rating in the Asset Store.
