Hi, anybody of you able to debug with us?
Hi, OnValue changed is an event triggered function which is managed by the subscriptions and it depends how the OPCUA server is calling it. Update itself is called in a regular manner. I think you might get values in the subscriptions because these might tell you all changes which the update function might miss because it is called in a cyclic manner.
this is a very old version with a different DLL for opcua. You should upgrade to the latest release.
Can you send us the project via realvirtual.io/send (please delete the library folder before) and we will debug it, to detect why the vector is not displaying on your side.
I have checked your scene. Please update to our latest version 2021.17 and the problem should be fixed. Let me know if there are any other problems.
Regards
Can you upload a project where we can reproduce the problem?
https://realvirtual.io/send
Hi, we never tested it but it should be possible because roboDK interface is working based on TCP-IP. But our experience with Hololens is not the best - we tried to do something similar but we did not succeeded in generating a good user experience and 3D performance of the hololens is very limited.
Which version of OPCUA are you using? We changed the basic dlls because there have been issues with encryption and so on. I think this is the reason. You should upgrade from the Unity Asset Store to latest version
