In our experience, IL2CPP compilation is often very problematic - this is often needed for WebGL and Hololens. Could we get the complete log file when building? Please also try closing Unity and deleting the Library folder and then reopening Unity so that everything is recreated.
Can we test this by installing your OPCUA server on our side or getting somehow remote access to your server?
Drive Limits should be respected in IK mode. I need to check but also in IK mode each solution is checked and if a point in the path is not reachable there should be a message. Will get back to you soon when I have checked the issue.
yes through the PLC might be a good choice. Do you know any kind of protocol we could use to communicate with Fanuc Roboguide?
Hi, I checked the issue. You are right - it is jumping slightly at each target.
It seems the the IK algorithm has some inaccuracy and we get a misalignment of up to 5mm at each target. This is the reason for the jump. We think that calculated tcppos by ik == wished tcppos.
As a solution I currently only see to implement a correctional vector at each target and to optionally safe the correctional vector as soon as you teach the point. We also need to start the next path from the latest wished tcp and not the real tcp based on the current tcp transform position. Because putting in the current real tcp will result in the jump due to the inaccuracy. The changes might take some time - I think I can send you a beta next Monday.
Hi, Parts4CAD is already included in Starter. If I understood you right you added it via the asset store.
After Starter package installation you should have this menu
As soon as you select Cadenas parts4cad the needed addtional executables are loaded into the streaming assets folder.
Path is the location in the control plane of the CPU. Most of the time "1,0".
