Hi, Is parts4cad now working for you? If not please give me your project (I have send you an email where you can upload it). I need to check in your project why it is not working for you. We can't see a problem here on our installations.
Hi, yes you can do that with Unity and Game4automation Starter. It is a little bit more complicated than for Android. You will need a Mac for final compilation (alternatively Unity’s cloud build) and an Apple developer account. In Unity’s build settings you will need to set IOS as Build target.
I don't know what your problem is because your the only one reporting this problem and here on our installation it works.
I have send you a link where you can upload your project.
as I can see from your screendump the Parts4Cad Windows Client seems to be downloaded to the streaming assets folder. I takes some time for the Parts4Cad Window to open. Are you sure that the window is not opened on another screen or behind another window. Please also turn off all your virus scan software.
With the latest Version of Parts4Cad and Game4Automation there might be a problem in combination. We detected the problem and will upgrade Parts4Cad the next days. Please try again Parts4Cad in a new empty project without Game4Automation.
If it still does not works please send us your project.
sorry we don't have a solution for the problem. Because of Unity is changing very fast we decided to relay on the Long Term Support releases which give long term support and better stability. So my advice is to use Unity 2018.4.8f1 and other 2018.4 Versions
Hi Tim,
there was a problem with the automatic settings of the defines.
Please check if the PLCOutput Script was added to your variable automatically:
If not please set in the defines manually "GAME4AUTOMATION" and reimport all OPCSignals.
Now it should work
Hi Tim,
I am wondering why the event doesn’t works with OPCUA in the Beta - I will check an make it work
I have send the mail to the mailadress you mentioned. I delete your last message because it is better - in this public forum - not to publish the mail adress. I will send you an email again.
