Normally this issue occurs if your axis coordinate systems are not set as they should.
Did you used this empty prefab which helps you for doing this (orientation of the coordinate systems of the 1st axis and no relative rotation in the sub axis)?
Assets/realvirtual/Professional/IK/EmptyRobotKinematic.prefab
the "OnExit" event of the sensor is triggered when a MU exits the sensor. If I understand correctly, you’ve attached the sensor as a component of the MU. In that case, it won’t work as intended.
We won’t be changing this in the release because the for-each loops account for the fact that a single MU can consist of multiple colliders, which the sensor may detect.
I recommend the following approach: place the sensor as a standalone GameObject at the end of your conveyor and use it to trigger your script.
Alternatively, you could use Unity's standard OnCollisionExit method on your own component attached to your MU.
1) it is a purely trigonometric solution which is able to caclulate all solutions (for standard industry robot kinematics). No real DH Parameters but positions and distanced of the joints are needed for calculating the solutions.
2) yes it works.
3) this would be possible with some coding
4) No I am sorry, we can't share the source code of the IK.
the current chain only functions with the drive component set to “virtual,” as configured in the sample scene. Using this setup, you should be able to build your device, and Unity physics should operate correctly in this case.
thank you for reporting this issue. We will fix this in the next release.
We are using a trigonometric solution which is able to calculate all possible solutions.
currently it isn't possible to rotate it off-center. We will work on this for the next release.
Maybe the AI pointed you into the wrong direction.
We have recorders like that:
https://doc.realvirtual.io/components-and-scripts/recorder#drives-recorder
But they write to scriptable objects and not to an external readable data structure.
You can check the scripts but you woule need to implement the data export based on your own needs.
Hi, for free joints you should use Unity Physic Joints, for fixed position controlled drive you should use our Drives - which are not using Physics. It is not possible to add our Drive to the Encoder you are showing.
