basically yes, we will release a new special Unity6 version the next days.
This is due to physics limitations. Kombining IsKinematic and physical transports is not possible. You should use parent drive function:
https://doc.realvirtual.io/components-and-scripts/motion/transportsurface#transport-surfaces-and-unity-physics
or GuidedTransport:
https://doc.realvirtual.io/components-and-scripts/motion/guided-transport
currently it isn't possible to enter values by keyboard using HMI-components. Those components only using signals from the PLC to set or get values. For having an element to enter values you have to set up your own UI using unity standard UI elements like canvas etc.. An example in realvirtual you'll find in realvirtual/UI. This is where our UI is implemented.
Thanks for the hint concerning "SignalIntStart", I'll fix this with the next release.
Hi, what do you mean with "recorders"?
We are usually using our Groups for Hiding things (using the SelectionWindow). We are currently working on an UI where you can also select the Groups to Hide or Display in Runtime but this is not released yet.
Hi, did you checked our Chain demo scene "DemoChain" - there you can see how we placed the points of the spline?
Hi, we will need to check this.
Please check that the TwinCATHMI Asembly Definitions are like that - or, if you don't need, delete fully TwinCATHMIin your project.
Please also try to close Unity, delete the Library folder out of the project and restart the project. Based on this it works on my machine.
