One more question - for me to be able to test. Is it a special issue when using multiple OPCUA interfaces in one scene or is it a generic issue also with one interface?
Ok will need to check. As an intermediate solution you could change to the latest release. There you can define a poll cycle for each node so the performance issue is solved when polling.
Are the values not updated correctly?
Can you please describe more how I should use your demonstration model you putted on our upload platform?
check the screenshot below. With 3D-Icon you can scale the gizmo size.
please check if the gizmos are enabled and check the scale of them.
Thanks, we will need to check.
We released a new version including what you requestet. It is version 2021.17. You can find it on the Unity Asset Store and on our download pages - depending where you purchased it.
Yes you will get a beta asap.
Could you please ask your question in English?
For the subscriptions I am totally sure that they are working. Is there a demo model with a demo opcua server where I can check your setup.
