Hi, we checked with our OPCUA demo server and reconnection works as expected. Can you describe a little bit more your setup so that we can try to reproduce the issue.
You are right - thanks a lot for reporting. Will be fixed in next release.
Hi, we are checking and looking for a solution.
Hi, we just checked and can't reproduce. Can you send us a full Unity project with everything in where we can test this. Please upload your project to https://realvirtual.io/send
Hi, you need to close the info window - then it should continue.
This utility was introduced in realvirtual.io Professional 6 and is only available in the Professional 6 release. If you’re still on the 2022 Pro version, you won’t see “Combine Meshes (Pro)” in your menus—this feature doesn’t exist in earlier 2022.x builds doc.realvirtual.io. To use it, you’ll need to upgrade your license and project to realvirtual.io 6.
