Can we look on your Screen with Teams for detecting the problem?
The answer of Christin is releated to another issue - not yours sorry.
What version are you using? This issue should be fixed in latest version. Basically you can ignore this error message.
you can find here a full example:
https://github.com/game4automation/game4automation-Community
Here is the RobotStudio Archive:
and here is the a robot with the suitable RobotStudio interface:
Hope this helps. If not we would need to debug on your computer - we don't have any more a robot studio license for testing.
please check the lists of your game objects in the inspector. This error can occur if a game object is not present in a list or is missing.
unpack the dupilcated prefabs complete and re-rarrage the elements of the slide button.
Regards
I see that ABB is not finding the UnityConnection. It seems that something is wrong configured on the ABB side. Will check tomorrow on the computer in the Office where ABB RobotStudio is installed if I can find our example project and send it to you. My advice would be also to first just start with a very simple config (e.g. just the axis values) and extend this later on as soon as the connection is up and running..
You seem to work on a non Windows Plattform. I think the space navigator drivers are the problem. Please delete the whole SpaceNavigator folder after importing the asset and select again "Apply Standard Settings"
Assets/game4automation/private/RuntimeUI/SpaceNavigator
it is only possible to combine Professional 2021 with Simualtion 2021, Professional 2020 with Simulation 2021 is not working.
Cheers
