Hi Mateo, did you find a solution. I was still not able to run your test server. Maybe you could also check https://github.com/nauful/LibUA/issues if you find anything related with your situation. If not we should maybe do a debug session via teams on your computer with your opcua server.
I am sorry for the problems. If you have problems you could downgrad to the OPCUA solution in our Version 2020.13 and before. But there were reasons for chaning to the new version. Mainly because of open source, pure .Net, Andoid, IOS and Hololens compatiblity. The new library is based on
https://github.com/nauful/LibUA/. But there are still issues and we are going to improve it in future.
PLCSIM is not officially supported. PLCSIM Advanced interface won't work with PLCSIM. But you can follow the guide apove and make it work with Nettoplcsim (see post above) and G4A S7-TCPIP interface . but it is not an official and supported solution from our side.
... and if you need a pulse encoder - sending pules every xxx millimeters, this will be available in one of the next releases. If you are a customer and purchased a professional version - please send us an email to info@game4automation.com with your Invoice and we can send you a beta of the pulse encoder.
Sie können mittels eigener C#-scripte für sich selbst eine solche Automatisierung schaffen. An Kunden können sie dies so nicht rausgeben, da diese dann ebenfalls eine Unity und game4automation Lizenz benötigen. Wenn sie ihre Anwendung als Build rausgeben benötigt ihr Kunde keine Lizenzen, allerdings müssen sie dann auch ein passendes UI erstellen.
I assume your question refers to a drive. In this case you can get the information directly from the drive by using the attribute "Current position". The handling of this
take place in your own C# script which you attach as a component to the game object where you need the information.
Game4Automation is an open and extensible platform. We have interfaces to many different tools. I'm sorry, but we can't afford to buy all the different tools available on the market and always upgrade to the latest version. So your support is very much appreciated.
Hi, I am sorry we just have PLCSIMAdvanced3.0. Are you able to downgrad to this version? Thanks.
Hi, I am not able to run the test server. Even if the path in your bat file is changed to our path. I am sorry we are not Python experts. Can you send it in a way so it is for sure running on our computer without any special Python configuration need?
What kind of OCUA Server are you using. Is there any possiblity that we test and debug with the same server?
