If this is the case try to increase the ReducedMaxPduLength.
The Value NegotiatedPdLuLength - ReducedPDuLength is used for the maximum length of the communication pdu.
If you don't succeed please send us your S7 project including your G4A Project.
Please follow https://forum.game4automation.com/de/knowledge-bases/2/articles/191-sending-us-your-game4automation-project-for-support for information how to send us the project.
There are errors in your console log. Please send the full log.
Sorry we can't tell you what is wrong based on this rough information. It could be your Unity Configuration or the OPC Server configuration .....
To be able to check it we would need an example based on an OPCServer we can test with.
Please try to rebuild your problem based on UaCPP C++ Demo server (will send you a download link for this test server in a private message later).
Please upload your project where you can reproduce your problem based on UaCPP Demo server here: https://game4automation.com/send
We are preparing a new release for end of next week and it is planned to fix this.
Please try to change OPCUA_Node.cs like this (about line 364):
We already changed that for the next relaease.
Hmmm... does it directly happens when you open the project on the new PC or only if you start the simulation?
We just implemented a new upload service.
You can upload your project here: https://game4automation.com/send
First picture shows that your project was still importing something and not ready to build.
I am able to build this scene based on the current release.
You need to make sure that cadimport is not part of your build because it is an editor only function and uses editor classes.
Usually it is done by excluding cadimport in the dll settings. This should be the case in your project. Maybe you referenced cadimport.dll somewhere in your scripts and this is why the build is not running. Please check what you added or changed in difference to the current release.
Mai is info@game4automation.com
So when you open the project on the new PC you get these white messages. This is not an error and we can ignore it.
When does the log with the Old PC Path comes up. When you start the RobotDK example project on the new PC. Normally this could not happen because on your new PC the Unity Log should not show log messages with the Old PC pathes. It does not seems to be a RoboDK specific issue.
How did you transferred the project to the new PC? Did you copied the full project folder. If yes usually you should delete Unitys Library Folder before opening on the new PC.
