You can do so, but you are not allowed to use one Unity or Game4Automation license on two computers at same time.
the license is tied to the organization who purchased the Asset. There seems to be no official way to transfer a license to another organization (e.g. from school to you personal) if you purchased on the Unity Asset Store.
You could purchase the license directly from us. For doing so please just fill out this form (Button "Request a quote" and you will get an offer: https://game4automation.com/en/buy
We could allow you the transfer if needed later on based on a simple mail you are sending to us.
the problem must be inside the included DLL. We agreed with our supplier of the DLL to wait to receive our Hololens2 to be able to test and to find the issue. For now we can only say that Hololens is not working (it was not only you who is not able to get it working).
Hi, tanks a lot.
The Application needs to write the certificates to an allowed folder path.
You could try to change the code here in OPCUA_interface to assign a path that is working on Hololens:
connection.UserName = UserName;
connection.Password = Password;
connection.MinCommCycleMs = WatchThreadMinCycleTimeMs;
connection.ClientCertificatePfx = ClientCertificatePfx;
#if !UNITY_IOS && !UNITY_ANDROID
connection.CertifcatePath = Path.GetFullPath(Path.Combine(Application.streamingAssetsPath, CertificatePath));
if (connection.ClientCertificatePfx!="")
connection.ClientCertificatePfx = Path.GetFullPath(Path.Combine(Application.streamingAssetsPath, ClientCertificatePfx));
#if UNITY_IOS || UNITY_ANDROID
connection.CertifcatePath = Path.GetFullPath(Path.Combine(Application.persistentDataPath, CertificatePath));
connection.ClientCertificatePfx = Path.GetFullPath(Path.Combine(Application.persistentDataPath, ClientCertificatePfx));
connection.Connect();
Please tell me if you found a solution for Hololens.
thanks a lot for the hint. We will check how we can prevent that and allow spaces in folder names. Didn't know that this causes problems.
you need to change this line (left = old, right = new) in the Drive script:
It will be changed in Release 1.024 (Build 246 and upwards).
For customers who wish a Beta download - please send us your Invoice Number and we can send you a download link!
I will check this tomorrow. For sure we will be able to fix it!
usually it should also work with 2019. But we recommend to use LTS (Long Term Stable) releases because Unity is sometimes changing to fast for industrial use cases. We develop and test in 2018.4. On our build server we also try to compile and build with 2019, but it is more risky that we miss something in 2019. So I would recommend to only use 2019 if you really need it.
I just checked latest release and 2019 and it works on my computer without problems. The main menu is available and the demo model is working as expected.
You should also check that you are using .Net4. compatibility level - even if this should be not an issue with the main menu. But some interfaces might not compile without .Net40
There seems to be an issue / collision with anything what is already in your 2019 project. I don't know what. Could you please check the Console log for some more information.
