note: I am using an LM Gateway201 as an OPC server
It did`n work
I tried read a node
NONE is checked in certificate
Use FX3U as modbus master. I use commands IVWR and IWRD. I use a RS485/ethernet converter
Did you make modbus work as client?
I noticed that to work as a client it is necessary to enter with ip, port and id (station number, which is a modbus address).
The field for id is missing
Will you implement this?
We use modbus in WEG PLC300 ,  mitsubishi FX3u, schneider and much more.
